MrRouterMan
Apr 07, 2022Aspirant
RAX200 Getting slow speeds with BT FTTP 900
Hi have BT Full Fibre 900 FTTP and recently purchased a Netgear Nighthawk RAX200. When I set it up directly connected to the BT openreach modem in router mode it gets between 430 and 550Mbps on its in...
microchip8
Apr 07, 2022Master
The internal Speedtest app is not very reliable or accurate. Try a different speed test like https://openspeedtest.com/ or Ookla
- MrRouterManApr 07, 2022AspirantThe average increased speed by around 200Mbps when set up in AP mode vs using as a router is consistent across all the various speed test tools for both wired and wireless clients.
- bobsbusiness84Sep 20, 2022Star
MrRouterMan Did you get anywhere with this?
I have the same problem when speed testing my new RAX200 on BT FTTP 900, couldn't get more than 480mbps down, it's always been a rock solid 930 on my Smart Hub, and even on a RAX120 I'd tried for a few days previously before having to send it back because of the random reboots.Weirdly i've plugged my BT Smart Hub 2 back in and have the SAME issue now, it can't download faster than 480mbps.
Either the RAX200 triggered a fault or something else strange is going on.
I'd like to know if you ever found a solution though?
