nwdiver1
Jan 31, 2021Follower
RAX200 Gigabit port to Gigabit Switch??
Can i use the Gigabit port to attache a Gigabit switch. I am having trouble using a Netgear Prosafe GS108 attached to the router.
pkgadd
Jan 31, 2021Luminary
Sure you can connect one of the LAN ports to your Netgear Prosafe GS108. Given that it is an unmanaged 8*1000BASE-T switch, it wouldn't really make sense to use the Multi-Gig port (although you can) - and you can't use Link Aggregation (LAG) without a managed switch, but there shouldn't be any problem to use it.
