JamesL1979
Apr 27, 2022Apprentice
RAX200 Hacked?
This morning access control on my RAX200 went crazy, lost all my blocked MAC addresses, System log showed a ton of messages with a large integer for the year, Armor notifcations full of new device notifications. I bought the RAX200 because of problems with access control issues on the R7900. What is going on guys?
1 Reply
What firmware version are you on?
What modem/gateway is it connected to?
Usually if more than 1 router has the same issue, it tends to not be related to the router.
If you have armor and think it might be related to armor, you could contact support.
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
