eastern_bloc_gu
Mar 25, 2021Tutor
RAX200 Homekit issues
RAX 120 Homekit issues Hi All, I changed from an Orbi RAC50 to a Nighthawk RAX200 router to upgrade my home network and since the upgrade I contantly have issues with my Homekit smart de...
Nansen
Jun 08, 2021Tutor
Had this issue before for previous FW, talked to support and they told me to disable smartconnect.
After the 1.0.4 FW update recently, the issue started again. enable/disable smartconnect won't help anymore. I'll switch to other brand for my next wifi 6E router.
- eastern_bloc_guJun 08, 2021TutorI gave up on this router. I tried loads of things to get it work, but all those unresponsive Homekit devices drove me nuts. I decided not to hold on to it based on a vague promise that this might be fixed in a future FW release. When in 3 months or 2 years? So got myself an Asus RT-AX89X,where everything worked out of the box no problem.
- NansenJun 08, 2021TutorToo late for me :( rolled back to previous FW and it’s working without smart connect. glad to hear that Asus works. Will go Asus for next upgrade
