FluidFactors018
Apr 15, 2023Guide
RAX200 in AP mode inaccessible, had to reset
Does AP mode truly work on the RAX200? I put mine into AP mode (keeping defaults), and it immediately stopped working for all intents and purposes. Wired clients could not get an IP address (even tho...
michaelkenward
Apr 16, 2023Guru - Experienced User
Is this what you did?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
When you did that, did you also restart your network in the right order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
For those who are wondering why in the world I would put the RAX200 into AP mode, I'm trying to avoid a double-NAT situation. My home is wired in a troublesome way, and the best location for a Wifi router is far from where the internet comes in (the latter being well-connected to wired jacks throughout the house).
Perhaps this is the source of your problem.
What actual modem/gateway is the RAX connected to in AP mode?
- FluidFactors018Apr 16, 2023GuideThe other router is a C4000XG, which I'm using as my CenturyLink gateway. Things worked _okay_ when I ran the network without it, but wireless was spotty in parts of the house, since the spot where the fiber enters the house is far from the best place for Wifi.
