Dfb1
Aug 13, 2021Initiate
Rax200 internet led - red
After power outtage (i had to install a lamp) my internet does not work. On the router the internet led is red and this color is not mentioned in the manual. I waited 2 days and it was still red. Re...
- Aug 13, 2021
what modem/gateway is it connected to?
have you powered off the modem and router?
then power on the modem first and give it a couple minutes,
then power on the router and give it a couple minutes.
Aug 13, 2021Guru - Experienced User
Dfb1
Buddy!
You have No idea how much time you saved me by avoiding a reset.
I really hope Netgear adds your fix to their manual.
Have the a super weekend, ya legend!
