Grumpyoldman32
Sep 05, 2020Tutor
RAX200 is TOTAL GARBAGE-if you are reseaching .......
I'm on my 2nd RAX200. The real-life expectancy for this is only 2 weeks. after that, your network goes into freak mode. The 1st the wifi kept dropping, then the wired LAN started to drop, put an old ...
Abusive
Sep 05, 2020Initiate
I must agree 100%! I own the r7800 and the r8500 both are superior routers to this. But that is only because on day one I installed dd-wrt software. The interface on netgear is for a child. You can barely change a Wi-Fi channel without some KIND of dfs error…. I figure some chinese kid is at the programing helm…I WOULD NOT SUGGEST THIS ROUTER TO ANYONE. IT’S YEARS BEHIND WHERE IT SHOULD BE. THE SOFTWARE IS TOTAL GARBAGE AND FULL OF ERRORS. LOOK AT THE FORUMS… SHAME ON YOU netgear. 500 FOR THIS IS A THEF!
