GrenadaV
Oct 17, 2021Guide
RAX200 Issues setting up replacing D7000
Hi all, Hopefully someone can help me out. I had a D7000 router and want to replace it with the new RAX200, have matched the settings of the D7000 with the RAX200 and I cannot get an internet con...
- Oct 25, 2021
Hi again Plemens,
Apologies for the delay in response, until yesterday I was still using the D7000, however I decided to try something I hadnt done yet.
I backed up the config file for the D7000, then tried to retore that to the RAX200, got an error message that it was in the wrong format.
Then out of the blue, I remembered a setting that was hiding in the depths of advanced settings.enabling VLAN which was on the D7000 but disabled on tjhe RAX200. Then instantly I got the connection.
Thanks everyone for your help, very much appreciated.
Kind regards
Rossco
plemans wrote:If its a new purchase, you get 90 days of free support.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.Might help with setup for you to be able to talk to some one :)
what firmware is on the RAX200?
gvillage
Oct 25, 2021Aspirant
Hi again Plemens,
Kind regards
Rossco
michaelkenward
Oct 27, 2021Guru - Experienced User
Was this some setting somewhere in the section in the manual Enable and Configure a VLAN?
