LockieFerguson
Nov 09, 2021Follower
RAX200 Issues setting up replacing D7000
Hi all, Hopefully someone can help me out. I had a D7000 router and want to replace it with the new RAX200, have matched the settings of the D7000 with the RAX200 and I cannot get an internet con...
Nov 10, 2021Guru - Experienced User
What ONT is it from the fibre company?
Have you contacted them about what settings are needed to connect?
Does your fibre company need vlan setup?
Again, I'd start with the fibre company for settings.
