Generik777
Jan 10, 2021Aspirant
RAX200 keeps disconnecting LAN devices randomly.
Most of my devices are WiFi but my PS4, PS5, and AppleTV are connected via Ethernet. It doesn't matter which device I am using it will randomly disconnect for a few seconds once an hour or so, someti...
michaelkenward
Jan 11, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
