darrensa
Jun 08, 2021Tutor
RAX200 keeps dropping off WiFI & Internet
Hi All. I purchased a NightHawk RAX200 last March, so just out of warranty! Over the past couple of weeks it keeps dropping all connections from the Network, Ethernet & Wifi. A reset of the rou...
Jun 08, 2021Guru - Experienced User
Sometimes "the latest" isn't always the greatest.
You could try downgrading the firmware a version or 2, doing a factory reset and reinstall. Then just disable auto-updates and see how it goes. It wouldn't be the first time a firmware update actually caused more issues than it fixed.
- darrensaJun 08, 2021TutorThanks I will give that a go. Is there a site which lists all the older firmware versions? I could only find the last version. And is it a pretty straightforward job? Thanks Darren
