Jasongufeng
Jun 23, 2022Aspirant
RAX200 keeps dropping wifi & internet for no more than ten days
I tried almost every firmware including the latest one. Some times it drops 5g. Sometime it drops 5g and 2.4g. Sometimes it drops 5g, 2.4g and internet. I add a fan outside. It's not the heat reason...
Jasongufeng
Jun 24, 2022Aspirant
The modem I use is China Telecom😁.
When it drops, sometimes I can connect to the console, sometime I cannot. Just like I don't connect to Netgear. I think the system crashes.
I don't use smart connect.
Could I use RAX120 firmware to refresh the system?😄
Many thanks!
Jun 25, 2022Guru - Experienced User
what chinese telecom modem is it?
No, you can't use the RAX120's firmware as its different hardware.
- JasongufengJun 26, 2022Aspirant
China Telecom,GPON ONU
中国电信,天翼网关
