GoranC
Apr 23, 2022Guide
RAX200 latest firmware update 1.0.6.138 will not start
Regardless of how I try to update to this latest firmware release (mobile app or from PC-browser) the update does not start. When searching from inside app/browser it returns an answer saying I alre...
- Apr 25, 2022
GoranC
Apr 23, 2022Guide
Now I've tried repeating the same procedure with both Chorme, Edge and Firefox. All with the same result - nothing happens. I guess there is something wrong with this update.
Goran C
Apr 23, 2022Guru - Experienced User
"nothing happens"
Does it error out? Does the page just reload? Does it give a notice of improper file?
- GoranCApr 23, 2022Guide
Hi,
No, there are no error messages or anything. When I click on "apply" the page seems to reload but no update process is triggered. The only thing that happens is that the box where I pointed to where the update file is stored on the hard drive now is empty again, so have have to point to it anew.
Thanks for your previous suggestions. Maybe this update is not available for my country (Sweden) as both the Nighthawk app and the update search from inside the application page after I've logged on, say that I already have the latest update. But there is no information about country restrictions on the dowload page for RAX200. It is a bit confusing:)
- plemansApr 24, 2022Guru - Experienced User
powered my rax200 on and tried it and it worked fine. I'd try a different pc
- GoranCApr 24, 2022Guide
Thanks for the suggestion. I just tried from a laptop but unfortunately with the same result. I realize I could try factory reset of the router and start all over from the beginning, but not sure it's worth the hassle. Wouldn't bother really as everything is running fine, if it wasn't for Netgear saying they have addressed some security issues in the latest update.
Thank you for your support.
- CD_router_888Apr 25, 2022Guide
- GoranCApr 25, 2022Guide
Hi, I'm not sure what you mean as I don't see a link or comment on what to do. Just a blurred icon looking like this:
Thanks for trying to help.
