olivethi
Jul 09, 2024Aspirant
RAX200 loose internet connection
Hello friends. I'm facing an issue with RAX200. Once a day i need to restart the router due to loosing internet connection on the extenders AX80 and also in the cable that I use direct in my PC. ...
Jul 10, 2024Guru - Experienced User
These extenders EAX80s?
How many extenders do you have connected?
What is the distance between the extenders and the RAX router? In Feet.
Does this happen with the extenders turned OFF?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
