StephenMA
Mar 23, 2020Aspirant
RAX200 Mesh?
Is the RAX200 a Mesh system? I have the EAX80 extender, which is a mesh extender, but can't seem to determine if the RAS200 router is mesh (or even if it matters)...?
- Mar 23, 2020
The SB8200 and the RAx support link aggregation. Are you using it? if so, disable it. its been known to be problematic for boht devices.
Another thing to try is to simplify. Remove the EAX and just run router and modem. If you still have the issue, then directly connect to the modem and run it for a while to see if you still have the issue.
The SB8200 also has modem connections page. you can take a screen of that and it shows the connection back to the ISP
Mar 23, 2020Guru - Experienced User
The RAX200 isn't a mesh system. The EAX is a mesh extender but paired together they're not a full mesh system. that'd be something like orbi.
- StephenMAMar 23, 2020Aspirant
Will Mesh be better via the Orbi than the RAX200? I keep getting drops with the RAX200 via my current extender system, which bugs me as the RAX 200 is an expensive router and I didn't expect those kinds of problems....
- plemansMar 23, 2020Guru - Experienced User
What modem are you using?
are both wireless and wired dropping?
Is it only the devices connected to the extender dropping?
What firmware is on each?
Is it specific devices dropping?
SB8200 3.1. I can't tell if its my ISP (Cox) that has the hickup or my router. I think it's Cox because I usually have to reset everything to get it back up and running... Frustrating....
