StephenMA
Mar 23, 2020Aspirant
RAX200 Mesh?
Is the RAX200 a Mesh system? I have the EAX80 extender, which is a mesh extender, but can't seem to determine if the RAS200 router is mesh (or even if it matters)...?
- Mar 23, 2020
The SB8200 and the RAx support link aggregation. Are you using it? if so, disable it. its been known to be problematic for boht devices.
Another thing to try is to simplify. Remove the EAX and just run router and modem. If you still have the issue, then directly connect to the modem and run it for a while to see if you still have the issue.
The SB8200 also has modem connections page. you can take a screen of that and it shows the connection back to the ISP
StephenMA
SB8200 3.1. I can't tell if its my ISP (Cox) that has the hickup or my router. I think it's Cox because I usually have to reset everything to get it back up and running... Frustrating....
Mar 23, 2020Guru - Experienced User
