djjuice
Nov 15, 2019Aspirant
RAX200 missing WPA3 option
I've setup a new RAX200 and have the latest firmware, yet I can't find any option in the security settings, or anywhere honestly to set a WPA3 option. I only see the usual (None, WPA2-PSK, WPA-PSK, W...
abogrhen
Nov 18, 2019Guide
what i know is the rax200 don't support WPA3
because the vendor don't support it
it is from the chipset inside of it (Broadcom)
the rax120 suport WPA3
as the chipset inside support it (Qualcomm)
but i have no idea if the will support it or just keep it for the future chipset
Nov 18, 2019Guru - Experienced User
My understanding is that it'll be supported. It has to trickle down from the chipset manufacturer but its planned to be implemented. Not sure when through.
