djjuice
Nov 15, 2019Aspirant
RAX200 missing WPA3 option
I've setup a new RAX200 and have the latest firmware, yet I can't find any option in the security settings, or anywhere honestly to set a WPA3 option. I only see the usual (None, WPA2-PSK, WPA-PSK, W...
abogrhen
Nov 18, 2019Guide
what i know is the rax200 don't support WPA3
because the vendor don't support it
it is from the chipset inside of it (Broadcom)
the rax120 suport WPA3
as the chipset inside support it (Qualcomm)
but i have no idea if the will support it or just keep it for the future chipset
djjuice
Nov 18, 2019Aspirant
Thanks for this information, this makes me consider returning the 200 for the 120, without any real knowledge of what's to come it appears the 120 has more futureproofing to it. I don't really need the 3rd band, but I do like the real 160Mhz.
- plemansNov 18, 2019Guru - Experienced User
I've never used the RAX120 but I do have the RAX200. As much as wp3 will be a nice implementation, the only device I have that supports it so far is a Intel AX200. There's other devices that do but none that I own so far.
