whital1
Jan 13, 2021Guide
RAX200 My router keeps dropping devices
My router keeps dropping devices, have updated firmware version rebooted router several times. Is anyone else having this problem. Is there a fix ?
Jan 14, 2021Guru - Experienced User
Dropping hardwired device?
only dropping wireless devices?
Are you using smart connect?
What firmware version are you actually on?
what modem/gateway is it connected to?
whital1
Jan 14, 2021Guide
No it is dropping wired and wireless.
I am smart connected
Firmware version v1.0.3.106
Spectrum modem
- plemansJan 14, 2021Guru - Experienced User
Which spectrum modem?
Have you tried a factory reset/reinstall on the RAX (not just a reboot)? They tend to respond favorably to those after firmware changes.
