gvmusic
May 05, 2020Follower
RAX200 Nighthawk AX12 - No Lan Connected while playing on my PS4, gets disconnected.
Nighthawk AX12 RAX200 is randomly causing a loss of connection. Error: No Lan Connect This occurs randomly, several times a week, while I am on my PS4. I lose connection and need to reboot my PS4, ...
Christian_R
May 07, 2020NETGEAR Employee Retired
Hi gvmusic,
May you provide us with the current firmware version the router is on.
Thanks,
Christian
- DefrostJun 03, 2020AspirantThis lan issue is happening to me as well.
My firmware was updated today. Ver. 1.0.2.88- BrianakabigbSep 07, 2020Initiate
Hi all,
I had the same issues with PS4 dropping completely with the RAX200 and the latest firmware. I did a downgrade to firmware 1.0.2.8 and it has worked perfectly since. I set the router to not automatically update until I know the newest version won't be terrible for the only reason I got the router. Hope it helps!
