gvmusic
May 05, 2020Follower
RAX200 Nighthawk AX12 - No Lan Connected while playing on my PS4, gets disconnected.
Nighthawk AX12 RAX200 is randomly causing a loss of connection. Error: No Lan Connect This occurs randomly, several times a week, while I am on my PS4. I lose connection and need to reboot my PS4, ...
Christian_R
May 07, 2020NETGEAR Employee Retired
Hi gvmusic,
May you provide us with the current firmware version the router is on.
Thanks,
Christian
Defrost
Jun 03, 2020Aspirant
This lan issue is happening to me as well.
My firmware was updated today. Ver. 1.0.2.88
- BrianakabigbSep 07, 2020Initiate
Hi all,
I had the same issues with PS4 dropping completely with the RAX200 and the latest firmware. I did a downgrade to firmware 1.0.2.8 and it has worked perfectly since. I set the router to not automatically update until I know the newest version won't be terrible for the only reason I got the router. Hope it helps!
