curtisbby
Apr 01, 2022Aspirant
RAX200 No LAN Ports, WiFi Fine
I have my RAX200 connected via LAN cable to the router from my ISP (Telus Fibre, not that it matters). Obviously it's plugged into the Internet port on my RAX200. The WiFi on my RAX200 works fine...
curtisbby
One update. For some odd reason, if I connect my PC to LAN port 5 (Multi-Gig) my Internet connection works fine. LAN ports 1-4 have no connection.
So everything works as I only needed to one LAN connection, but in the future if I want to add more I'd still like to get ports 1-4 working.
Apr 01, 2022Guru - Experienced User
what modem/gateway is it connected to?
What firmware is on the router?
