maughanorama
Jan 06, 2025Aspirant
RAX200 no power
Hi my RAX 200 is out of warranty and will no longer power up. i have found the faulty component ( diode with a hole in it) however im unable to see the part number. could some one tell me th...
Jan 06, 2025Guru - Experienced User
You'll need to contact NG support and see if they will give that to you. Usually no information about parts here or given by NG.
Might try something generic.
Good Luck.
maughanorama
Jan 07, 2025Aspirant
hmm its a sad time when we have to throw away devices just because the company wont release circuit diagrams
ill try an educated guess and see how i get on
- FURRYe38Jan 07, 2025Guru - Experienced User
If you find another router, could check it to see a meter would let you know anything. The power diode should be fairly standard across these router having the same power specs for the higher end RAX and RAXE models.
- maughanoramaJan 08, 2025Aspirant
yer problem is trying to find anything that does not break the bank
- FURRYe38Jan 08, 2025Guru - Experienced User
đ
