maughanorama
Jan 06, 2025Aspirant
RAX200 no power
Hi my RAX 200 is out of warranty and will no longer power up. i have found the faulty component ( diode with a hole in it) however im unable to see the part number. could some one tell me th...
maughanorama
Jan 07, 2025Aspirant
hmm its a sad time when we have to throw away devices just because the company wont release circuit diagrams
ill try an educated guess and see how i get on
Jan 07, 2025Guru - Experienced User
If you find another router, could check it to see a meter would let you know anything. The power diode should be fairly standard across these router having the same power specs for the higher end RAX and RAXE models.
- maughanoramaJan 08, 2025Aspirant
yer problem is trying to find anything that does not break the bank
- FURRYe38Jan 08, 2025Guru - Experienced User
đ
