Steveosupremo
Oct 02, 2021Initiate
RAX200 no USA option
So I just updated to version 1.0.5.132 and after I updated I was not able to select America (USA) as the region. I have lost a lot of WiFi range, and is just not good anymore. Anyone know whi...
Steveosupremo
Oct 04, 2021Initiate
This is in the wireless setup area. under advanced.
psychopomp123
Oct 05, 2021Luminary
Ah yes I can see it now, but region setting is greyed out, ie its locked to region where you purchased it and cannot change it. AFAIK on the RAX200 its always been like that on all firmware versions. Do you not see the screen below?
- michaelkenwardOct 06, 2021Guru - Experienced User
This seems to be the case for things sold in the USA, perhaps for legal reasons. Other countries don't see the same lockdown.
On some devices there is a way to unlock that setting.
Here is an earlier conversation about different hardware:
Solved: WNDR3700v2 (N600) - Can't change wifi region - NETGEAR Communities.
Sadly, this relies on the ability to enable Telnet on a router, something that Netgear is making harder by the day.
More here:
Search - NETGEAR Communities - burnsku
