Raxmo
Jul 30, 2022Tutor
RAX200 not letting some devices connect to the internet via wifi.
I replaced my NETGEAR 1700 router a few weeks ago with the RAX200. It was fairly easy to set up but over the last couple of weeks I found that my Ring app and my Dish receiver would connect fine to t...
Jul 30, 2022Guru - Experienced User
Try disabling AX mode on each radio and see if this helps...
Try with Smart Connect disabled...
- RaxmoJul 30, 2022Tutor
Thank you, it seems to have reverted back to it no communication issue again. I tried turning off the AX and the Smart connect, and it will actually show the cameras are there but won't communicate with them in Live mode. Dish is back to not communicating.
- FURRYe38Jul 30, 2022Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- RaxmoJul 30, 2022Tutor
- FW version, V1.0.10.140
- ISP isd, Ziply fiber (i have dsl because FO isn't available to me yet)
- ARRUS router, model # NVG4438
