BenjaminS
Jul 26, 2020Aspirant
RAX200 not recognizing internet from CM1200
Hello All, I am hoping that you can help since my tech support expired 6 days ago after buying these two devices: RAX200 and CM1200. Everything was working fine till this morning. The router i...
RajaDaja
Jul 26, 2020Luminary
Physically disconnect modem from the router via internet cable, then remove the power source to the modem. Turn off router using push button switch, remove power source to router. WAIT 5 minutes then get the modem up and running, connect network cable to router and then turn on router.
