Retired_Member
Nov 13, 2021RAX200 not showing internet speed in QoS
My RAX200 used to show internet speed per device. This is no longer showing. All devices show 0.00 Mbps. I've tried returning and using another RAX200, and for an hour or two it showed the speeds, ...
michaelkenward
Nov 13, 2021Guru - Experienced User
For once this isn't a generic question so you really should try this question in the appropriate section.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
By the way, the need for QoS seems to be dying as Internet speeds get above the levels where it is of any use. Indeed, the general view is that if your Internet is > ~ 200 Mbps it will only slow things down as the processor struggles manage traffic..
Retired_Member
Nov 13, 2021What a useless reply.
First of all if you’re going to be useless and provide no help, at least use grammar correctly. It’s “for one”, not “for once”.
Second of all, you’re opinion regarding QoS wasn’t what I was searching for. I was searching for answers as to why a feature of a paid product isn’t functioning as expected.
Go be useless elsewhere or find something meaningful to do with your time kid.
- michaelkenwardNov 13, 2021Guru - Experienced User
I was searching for answers as to why a feature of a paid product isn’t functioning as expected.Got that wrong then.
Then again, the grammar there is a bit mangled. "a paid product"?
- Retired_MemberNov 13, 2021Well it’s not free lmao.
You okay there bud?
