Retired_Member
Nov 13, 2021RAX200 not showing QoS speeds.
My RAX200 used to show internet speed per device. This is no longer showing. All devices show 0.00 Mbps. I've tried returning and using another RAX200, and for an hour or two it showed the speeds, a...
Nov 14, 2021Guru - Experienced User
Maybe the version you're on has a bug. Have you downgraded the firmware?
Retired_Member
Nov 14, 2021Yes, I've tried this and same issue.
- plemansNov 15, 2021Guru - Experienced User
what speeds do you pay for?
That feature usually just displays the bandwidth you're on.
And if you're paying for over 250mbps, it isn't recommended to use qos anyway as it can cause slow downs/latency
