Retired_Member
Aug 05, 2020RAX200 NTP Time Frozen
Anyone else have a frozen time and date in the NTP time section? Mine is frozen on Monday the 3rd at 0930 when I did the .98 FW update. I always do a paper clip reset after an update but for some r...
jcax
Aug 05, 2020Star
This appears to be a bug introduced with the .98 firmware. Other models (including mine) affected. Some have downgraded back to previous firmware and confirmed it.
dglsmcd_USMC
Aug 06, 2020Luminary
No problem here with the 98 firmware updatee-NTP functions normally-not sure what the fix is....
- dglsmcd_USMCAug 06, 2020Luminary
Ok, spoke too soon as I have now successfully broke the NTP setting with firmware 98 :smileysad: Trying to troubleshoot to see if there is a workaround fix-will update later
- Retired_MemberAug 07, 2020
Semper Fi
- Christian_RAug 11, 2020NETGEAR Employee Retired
Hello Nighthawk AX Users,
I have forwarded the feedback to our product teams for further investigation. I'll update the thread with further details as soon as I can.
Regards,Christian
