Retired_Member
Aug 05, 2020RAX200 NTP Time Frozen
Anyone else have a frozen time and date in the NTP time section? Mine is frozen on Monday the 3rd at 0930 when I did the .98 FW update. I always do a paper clip reset after an update but for some r...
dglsmcd_USMC
Aug 06, 2020Luminary
No problem here with the 98 firmware updatee-NTP functions normally-not sure what the fix is....
dglsmcd_USMC
Ok, spoke too soon as I have now successfully broke the NTP setting with firmware 98 :smileysad: Trying to troubleshoot to see if there is a workaround fix-will update later
- Retired_MemberAug 07, 2020
Semper Fi
- Christian_RAug 11, 2020NETGEAR Employee Retired
Hello Nighthawk AX Users,
I have forwarded the feedback to our product teams for further investigation. I'll update the thread with further details as soon as I can.
Regards,Christian
- MEZIANIAug 13, 2020Aspirant
Hello,
There are critical bugs on this version :
- NTP
- Wifi instability with Smart Connect (router reset required)
When will we have a release version, please?
- Christian_RAug 14, 2020NETGEAR Employee Retired
Hi MEZIANI,
Our product teams are currently working on a new firmware version. We do not have an ETA on the next firmware version update.
Christian
- SynomenonAug 14, 2020Star
Mine isn't frozen, but when I change the time zone to MY time zone and hit apply, it changes back to the default (I think mid-west time zone).
- Christian_RAug 17, 2020NETGEAR Employee Retired
Hi Synomenon,
Does the issue persist when reverting back to the previous firmware version?
Christian
- SynomenonAug 17, 2020Star
Christian_R wrote:Hi Synomenon,
Christian
I'm going to attempt rolling the firmware back to v1.0.2.88 tonight to see if it fixes the time zone and NTP issues, however one of the issues I'm randomly experiencing (RAX200 loses internet connection with modem):
has happened with multiple firmware versions.
