Trex6's avatar
Trex6
RAX200 Only Wifi Light on - can't connect
I just received the nighthawk router today. However when I switch on no lights are on except the wifi light below. connecting an ethernet cable, mac says it is unplugged. The wifi is not visible and ...
  • Trex6's avatar
    Dec 08, 2020
    the power was not on neither so sent back the device. the one which came today works.
