adm1r4lj
Oct 02, 2019Star
RAX200 OpenVPN connection fail from reomote IP address error
I can't get an Android client to connect to the OpenVPN server running on an RAX200 running Firmware Version V1.0.1.8_1.0.39. Router logs are showing the following error: [OpenVPN, connection fail] ...
Altsai
Oct 02, 2019NETGEAR Expert
did you ever try different port# above 1000? say 8443?
adm1r4lj
Oct 04, 2019Star
Yes. Tried typical high ports... 8080, 8443, 5353, also the netgear defaults of 12973 among others, still nothing. Only thing in the Android client log is:
09:42:23.641 -- Connecting to [XXXXXXX.ddns.net]:12973 (X.X.X.X) via UDPv4
09:42:33.632 -- EVENT: CONNECTION_TIMEOUT trans=TO_DISCONNECTED
This is the output of the Android client connection log:
09:42:23.596 -- ----- OpenVPN Start -----
09:42:23.597 -- EVENT: CORE_THREAD_ACTIVE trans=TO_DISCONNECTED
09:42:23.608 -- OpenVPN core 3.git::728733ae:Release android arm64 64-bit PT_PROXY built on Aug 14 2019 14:13:26
09:42:23.609 -- Frame=512/2048/512 mssfix-ctrl=1250
09:42:23.609 -- UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
6 [persist-key]
7 [persist-tun]
13 [verb] [5]
09:42:23.610 -- EVENT: RESOLVE trans=TO_DISCONNECTED
09:42:23.634 -- Contacting X.X.X.X:12973 via UDP
09:42:23.634 -- EVENT: WAIT trans=TO_DISCONNECTED
09:42:33.684 -- EVENT: CORE_THREAD_INACTIVE
09:42:33.685 -- Tunnel bytes per CPU second: 0
09:42:33.687 -- ----- OpenVPN Stop -----
- arjewell23Nov 09, 2019Star
I too am having issues with OpenVPN on my RAX200. I have tried many different configurations and ports.
- arjewell23Jan 14, 2020Star
I think I figured out the OpenVPN timeout connection, etc. I spent hours tonight checking one setting at a time and then looking at the logs. I finally noticed that everytime I was trying to connect, the logs kept saying "to" an internal IP address. It looked familiar and I realized it was tyring to connect to my "Default DMZ Server" ip address which is my PS4. I turned it off and hit apply. It connected immdiatly. I hope this helps at least one person as I have spent hours upon hours trying to figure this out. "[OpenVPN, connection successfully] from remote IP address:"
- Christian_RJan 16, 2020NETGEAR Employee Retired
arjewell23,
We appreciate you sharing your experience and updating the thread!
Thank you,Christian
