adm1r4lj
Oct 02, 2019Star
RAX200 OpenVPN connection fail from reomote IP address error
I can't get an Android client to connect to the OpenVPN server running on an RAX200 running Firmware Version V1.0.1.8_1.0.39. Router logs are showing the following error: [OpenVPN, connection fail] ...
arjewell23
Jan 14, 2020Star
I think I figured out the OpenVPN timeout connection, etc. I spent hours tonight checking one setting at a time and then looking at the logs. I finally noticed that everytime I was trying to connect, the logs kept saying "to" an internal IP address. It looked familiar and I realized it was tyring to connect to my "Default DMZ Server" ip address which is my PS4. I turned it off and hit apply. It connected immdiatly. I hope this helps at least one person as I have spent hours upon hours trying to figure this out. "[OpenVPN, connection successfully] from remote IP address:"
Christian_R
Jan 16, 2020NETGEAR Employee Retired
arjewell23,
We appreciate you sharing your experience and updating the thread!
Thank you,
Christian
