wase471111
Jun 07, 2020Apprentice
RAX200 or Orbi ax6000?
so, been using the orbi wifi 6 3 piece system for a few months now, and only a couple of issues, like the random internet disconnects that are talked about all over the web...wifi speeds are fantasti...
Jun 08, 2020Guru - Experienced User
I don't have the orbi AX but I do have the Orbi AC and I have the RAX200.
If it was me? I'd stick with the orbi setup. Its a true mesh system with some bugs getting ironed out.
It might take a bit though.
The RAX isn't mesh and adding a mesh extender doesn't make it a true mesh.
I actually went back to my using my orbi AC mesh versus my RAX200. I use the rax now for testing out AX devices.
wase471111
Jun 09, 2020Apprentice
Yeah, its impossible to imagine anything being faster than the Orbi AX; the occasinal drop outs are annoying, and, the firmware, although better than at first, is still really buggy and lacking any sort of advanced features.
I coulld sell my 3 unit orbi now for more than I paidf for it 5 months ago, so it is tempting..
Problem is, not alot of folks have much good to say about the actual performancxe of the RAX200, so that is concerning..
- psychopomp123Jun 09, 2020Luminary
Usually people only post on forums when they have issues with a product - the RAX200 is no different.
I've had my RAX200 for a ~ 6 months ago and its the best router I've ever owned for wifi. Sure, there were a few bugs at the beginning but i find it rock solid now. The RAX200 is far more stable against Asus' offering, the GTAX11000, which is still buggy as hell despite Asus releasing a firmware update for it every 2 minutes.
- wase471111Jun 09, 2020Apprentice
I had the same Asus router, and had the same issues with instability; I was going to buy a RAX200 in the beginning, but, I had read nothing but complaints about it; True, as you say, people only post when they have issues, but it seemed liike almost everyone did.
I have had the Orbi AX wifi 6 since January, and it has also had issues on and off; the firmware/software was an embarassment, but, they did a decent update a week or 2 ago, and now at least,we have Netgear Armor, but you still cant do anything wiith their lightweight, flimsy software/firmware.
The RAX200 looks like its super stable now, and the price has come down too; problem is, I need some sort of extender.AP in my garage for my POE camera, and having the 3 Orbi kit made it easy to put one out there, with no slow downs either.
I'm concerned if I switch to the RAX200, whatever Extender/AP I add, unless its a triband AX, which they do NOT offer at this point, will slow down my wifi speeds..It appears that either the EX8000, a tri band, but AC extender, or the EAX80, a dual band, but AX extender would be my 2 best choices..
I get between 400-800MB on wifi everwhere on my property with my 1GIG Cox connectioon, using my Orbi 3 unit AX system
thanks
- psychopomp123Jun 10, 2020Luminary
Can't you buy the RAX200, say from Amazon, and return it back for a full refund if it doesn't meet your expectations? FWIW my RAX200 even gives me a fairly good signal to main road about 100 metres away!
