Kithron
Jan 13, 2021Aspirant
RAX200 Orange wan light after rebooting it along with CM2000 via GUI
Hello All, I have a strange issue. I've rebooted my new RAX200/CM2000 together via GUI and my RAX200 has an orange light for wan. The only way to get to get it back to white is rebooting my CM20...
Jan 14, 2021Guru - Experienced User
it might be the RAX rebooting faster than the CM2000 and not getting an ip adress right away.
Have you tried powering both off, then powering up the cm2000 and giving it a couple minutes and then powering on the rax?
michaelkenward
This is exactly what happened to me. After power cuts the modem (a D6400 in modem only mode) was so slow to connect to the Internet that the R7800 attached to it timed out.
I installed a DM200 instead of the D6400.
It is well known advice – straight out of the documentation – that the network boot order is important.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
