Kithron
Jan 14, 2021Aspirant
RAX200 Orange wan light after rebooting it along with CM2000 via GUI
Hello All, I have a strange issue. I've rebooted my new RAX200/CM2000 together via GUI and my RAX200 has an orange light for wan. The only way to get to get it back to white is rebooting my CM20...
Jan 14, 2021Guru - Experienced User
Usually you have to boot up the modem first. Interesting that it works that way with your device.
wonder if its a function of using the 2.5g port on it.
Does it do the same if the router is connected through the 1gig wan port?
Kithron
It doesn't matter which port I use. I've tried it on the multi-gig 2.5g/1g port and the internet port and the same behavior exists.
plemans wrote:Usually you have to boot up the modem first. Interesting that it works that way with your device.
- plemansJan 14, 2021Guru - Experienced User
Hate to say it but so long as it works, I wouldn't worry about it.
Makes it a bit of a pain when power dies/flickers but if it bothers you enough, pick up a cheap UPS to prevent that from being an issue.
- KithronJan 14, 2021Aspirant
Was planing to get a UPS in the future, it really doesn't bother me atm but I'll forward this to NG Support to let them know there an issue with this.
