Memmaatre
Nov 10, 2021Aspirant
RAX200 PMF how enable?
Hi, I cannot find PMF settings on/off on RAX200. Is it called anyting else than PMF? Br Mem
Nov 10, 2021Guru - Experienced User
PMF is required for all newer certified devices.
So its built in
Memmaatre
Thanks but I read that it could be disabled also in RAX200 interface, Advanced/Advanced setup or something. Cannot find it.
- plemansNov 10, 2021Guru - Experienced User
What are you trying to disable it for?
Some models have that option. Not sure about the RAX200 though.
Maybe a better idea of what you're trying to do and why might help us to help you
- MemmaatreNov 10, 2021Aspirant
Please read this post:
Re: Does the RAX120 product support PMF? * PMF (Pr... - NETGEAR Communities
Ive also read the manual for RAX200 but it says absolutely nothing about PMF. My goal is to make sure that its enabled and to know where for confirmation. If its automaticly on @RAX200 it should at least be mentioned in the manual?
The RAX120 is different hardware. It has a qualcomm processor.
The RAX200 is a broadcom.
There's going to be variations in the routers based off their hardware.
If it doesn't have an option for it, it means its enabled as its part of the wpa3 spec to be required to be enabled with wpa3.
