Tam_Khamchui
Dec 01, 2019Aspirant
RAX200 problem streaming Netflix and local streaming with Android
Hi I'm Tam from Thailand, I try to test RAX200 with streaming app Netflix and local streaming by ISP for iOS is ok but for Android is not work problem only 5GHz for 2.4GHz is ok. How to fix problem.
Thank you
Thank you
1 Reply
- Tam_KhamchuiAspirant
Have more deatail for RAX200 problem with Netflix for Wan DHCP mode still problem but PPPoE should be ok can work for Netflix.
For DHCP mode I try to use speedtest app for download is ok upload can't test.
