EmSshi
Apr 30, 2021Aspirant
RAX200 randomly rebooted
Hi guys, These days, my router rebooting often occur. I checked the firmware update and reset the settings, but the symptoms are still there. Could this be caused by hacking attempts? What can ...
Apr 30, 2021Guru - Experienced User
Did you reset or reboot? By reset I'm implying a factory reset. Push and hold reset for 7-15 seconds while its powered on.
Is it automatically rebooting?
Have you tried a different outlet in case its a power issue?
Did you try reinstalling or downgrading the firmware in case thats the issue?
EmSshi
May 02, 2021Aspirant
In this case, it will reboot suddenly without any notice.
I couldn't change the power because there were no other products.
Even if I changed the firmware that come from netgear public support center, it's a private firmware, I reset and reinstalled it, but the symptom did not improve.
They will replace or repaire with RMA through official support.
Thanks for your comment.
