UserRax200
Jul 11, 2022Aspirant
RAX200 Readyshare issue: change mount path after router reboot
Hello, I have this issue on RAX200 for a while now on different FW version. The latest one I have is 1.0.6.138. I considered raising support case, until I saw that it's required some subscriptio...
iyang
Jul 13, 2022NETGEAR Expert
Hi UserRax200 ,
Do you mean that Share Name(\\readyshare\P_mount) be change after every reboot ?
Thanks
- UserRax200Jul 13, 2022Aspirant
Yes.
The "Share Name" changes (like \\readyshare\M_Drive, \\readyshare\P_Drive) because the "Folder Name" changes (M:\, P:\, O:\...), same as the "Volume Name" (M Drive (460.3G) or P Drive (460.3G), or O Drive....).
It's obviously consistent like if it's M: then every naming keeps name. But it changes after every router reboot.
- iyangJul 14, 2022NETGEAR Expert
- UserRax200Jul 16, 2022AspirantHi, I cannot provide screenshots for now.
It was just created using default readyshare options...Nothing exotic
