UserRax200
Jul 11, 2022Aspirant
RAX200 Readyshare issue: change mount path after router reboot
Hello, I have this issue on RAX200 for a while now on different FW version. The latest one I have is 1.0.6.138. I considered raising support case, until I saw that it's required some subscriptio...
UserRax200
Jul 20, 2022Aspirant
Maybe it's due to the USB disk size (512gb),maybe it was when it's fat32, now it's NTFS. I don't know I can just tell you it's bugging here.
iyang
Jul 20, 2022NETGEAR Expert
- UserRax200Jul 21, 2022Aspirant
And can I ask you to pay attention to the description I provided in the first post?
- UserRax200Aug 07, 2022Aspirant
drive name is J 10 min after (I rebooted the router using the GUI once)drive name was K 10min earlier
firmware version (latest)
- michaelkenwardAug 09, 2022Guru - Experienced User
What is the modem/gateway in front of the router?
What does Windows show in Networking?
ReadySHARE issues can sometimes show up there.
I have this issue on RAX200 for a while now on different FW version. The latest one I have is 1.0.6.138.That is not the latest.
RAX200 Firmware Version 1.0.10.140 | Answer | NETGEAR Support
You might find it useful to experiment with "Alt+Print Screen" in Windows. Your camera shots are almost impossible to read.
Alt+Print Screen - Google Search
- UserRax200Aug 10, 2022AspirantAs you can see the latest version of the firmware is indicated just one post above yours.
note that at the time of writing my first post, the firmware I indicated was the latest.
Anyway the issue is present with any firmware.
I have no issues in Windows with Readyshare. The modem is a fiber modem ZyXEL AX7501-B0 - michaelkenwardAug 11, 2022Guru - Experienced User
UserRax200 wrote:
The modem is a fiber modem ZyXEL AX7501-B0This thing?
It describes itself as Dual-Band Wireless. That usually denotes an integrated router. If that is the case, then piling router oin router can be awkward.
I have no issues in Windows with Readyshare.So \\READYSHARE is visible and accessible in Windows?
I see no indication that you have tried different USB devices with ReadySHARE.
This is a (hopelessly inaccurate) list of the things that are known to work with ReadySHARE:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
- UserRax200Aug 27, 2022Aspirant
Thanks for the help.
- Yes thats the device.
- You are correct, but I disabled DHCP on one routeur, etc....(I can't set the ISP to bridge they don't let you do that)
- Yes it is accessible and visible from windows. Ex now: \\readyshare\D_Drive
- The list is very limited 🙄... We're talking about a simple usb key here... That gives quite a bad impression of Netgear to me (in addition to their support with idiotic and unrelated questions PS: I'm in the field for 20 years or so)
