lfryejr
Jun 14, 2020Tutor
RAX200 Readyshare Issues
I recently rebooted my RAX200 and after doing so, the Readyshare feature no longer works. Readyshare is recognized on the routerlogin.net page but Readyshare is not accessible when I try to access f...
Christian_R
Jun 17, 2020NETGEAR Employee Retired
Hello lfryejr,
May you let us know the current firmware version your router is on?
Thanks,
Christian
lfryejr
Jun 20, 2020Tutor
I updated the firmware two weeks ago. However, I tried to access the router via the iPhone app and routerlogin.net and neither can find the router. I rebooted the router with the button, cycling the power off for 30 seconds. Some of the wifi channels are working but it is not consistent.
Need help to determine how to reconnect and resolve.
- lfryejrJun 20, 2020Tutor
I was able to get it to connect after a couple reboots. The firmware version is V1.0.2.88_1.0.50
I also found that I can access the readyshare using the HTTP Access Method but the Network Neighborhood/MacShare and FTP do not even while they show enabled.
