retiredat56
Jan 20, 2021Aspirant
RAX200 Reboot and NO IP Address
I have an RAX200 WIFI router. Whenever I reboot my RAX200 and modem, I cannot get an IP Address for any of my devices. My PC will not reconnet and it says No Ethernet IP address. My phone will not...
retiredat56
Jan 21, 2021Aspirant
Firmware is RAX200_V1.0.3.106_1.0.68 (I believe the latest)
Modem is an Arris SB8200
I've rebooted other routers and never consistantly lost the IP address for my devices. I was even instructed to run IPCONFIG /RELEASE and IPCONFIG /RENEW off my PC to help fix the issue, but with no success.
Jan 21, 2021Guru - Experienced User
Are you using wan port aggregation? If so, disable it. The SB8200 has had issues with wan port aggregation.
