Bustermagic
Mar 29, 2025Aspirant
RAX200 Reduction is connection speed to ISP.
Hi all, I have a RAX200 and was on a 5000mpbs download connection with my ISP which worked fine, I recently upgraded my ISP connection to 900mbps but the router would only connect at 500 to 6...
Mar 30, 2025Guru - Experienced User
did you try factory resetting it after the update? I'd also leave access control, traffic monitoring, and parental controls all disabled.
- BustermagicMar 31, 2025Aspirant
Hi,
Yes, the router was reset to factory each time and no additional features were added. It seems to be a firmware issue or a new feature in the firmware.
Dave
- plemansMar 31, 2025Guru - Experienced User
You might need to play around a little. The RAX200 hasn't had much for updates in quite a while so I doubt they'll be doing much with it. Its worthy trying to turn on/off services. Or even disabling some of the logging features that aren't needed.
I will give it a go - thank you.
