Bustermagic
Mar 29, 2025Aspirant
RAX200 Reduction is connection speed to ISP.
Hi all, I have a RAX200 and was on a 5000mpbs download connection with my ISP which worked fine, I recently upgraded my ISP connection to 900mbps but the router would only connect at 500 to 6...
Mar 30, 2025Guru - Experienced User
did you try factory resetting it after the update? I'd also leave access control, traffic monitoring, and parental controls all disabled.
Bustermagic
Mar 31, 2025Aspirant
Hi,
Yes, the router was reset to factory each time and no additional features were added. It seems to be a firmware issue or a new feature in the firmware.
Dave
- plemansMar 31, 2025Guru - Experienced User
You might need to play around a little. The RAX200 hasn't had much for updates in quite a while so I doubt they'll be doing much with it. Its worthy trying to turn on/off services. Or even disabling some of the logging features that aren't needed.
- BustermagicMar 31, 2025Aspirant
I will give it a go - thank you.
- BustermagicApr 06, 2025Aspirant
It's 100% a firmware issue. I was going to go through the two firmware files I have to identify the change between both but have decided that I'm going to look for a custom firmware to fix this issue. It's a shame that the software side of this router lets it down.
