Nightcat
May 29, 2020Aspirant
RAX200 Router not found with Nighthawk Android app after V1.0.2.88_1.0.50 update.
Updated the nighthawk android app and routers firmware to V1.0.2.88_1.0.50 and im getting router not found messege help.
Nightcat
Jun 02, 2020Aspirant
Christian_R wrote:Hi Nightcat,
If you haven't done so already, may you perform a factory reset on the router after a firmware update.
Christian
Did a factory reset and still says router not found, even when choosing setup a new device.
Christian_R
Jun 03, 2020NETGEAR Employee Retired
Nightcat - Thanks for confirming. May you provide me with the current Nighthawk app version you have installed on your android device.
Thanks,
Christian
- NightcatJun 04, 2020AspirantAndroid app version 2.5.4.1036
