Nightcat
May 29, 2020Aspirant
RAX200 Router not found with Nighthawk Android app after V1.0.2.88_1.0.50 update.
Updated the nighthawk android app and routers firmware to V1.0.2.88_1.0.50 and im getting router not found messege help.
RajaDaja
Jun 04, 2020Luminary
Log into your router thru web browser:
router login.net or routerlogin.com
If you haven’t, set your router up.
Look to enable; Remote Management.....
under advance tab or admin
Nightcat
Jun 04, 2020Aspirant
RajaDaja I did enable remote management it still won't connect for me.
When i click the apply button when enabling remote management the router doesn't reboot or confirm that its on.
- RajaDajaJun 04, 2020LuminaryGo off wi-fi then open nighthawk app. As the app loads at the bottom click on the purple banner connect remotely or to that affect.
