Nightcat
May 29, 2020Aspirant
RAX200 Router not found with Nighthawk Android app after V1.0.2.88_1.0.50 update.
Updated the nighthawk android app and routers firmware to V1.0.2.88_1.0.50 and im getting router not found messege help.
Nightcat
Jun 04, 2020Aspirant
RajaDaja I did enable remote management it still won't connect for me.
When i click the apply button when enabling remote management the router doesn't reboot or confirm that its on.
RajaDaja
Jun 04, 2020Luminary
Go off wi-fi then open nighthawk app. As the app loads at the bottom click on the purple banner connect remotely or to that affect.
- NightcatJun 05, 2020AspirantRajaDaja
Turned off wifi and tried connecting remotely through 5g network and it still says no devices detected.- RajaDajaJun 05, 2020LuminaryWow! One final thought...... Uninstall the App if you haven’t already and reinstall. Good luck!👍🏼
- RajaDajaJun 05, 2020LuminaryI believe the app is faulty. Since the app update I noticed it takes longer to detect router when opening the app and sometimes the login process glitches and takes you back to the login screen. Any who, I thought this might help to understand you situation.
