Nightcat
May 29, 2020Aspirant
RAX200 Router not found with Nighthawk Android app after V1.0.2.88_1.0.50 update.
Updated the nighthawk android app and routers firmware to V1.0.2.88_1.0.50 and im getting router not found messege help.
Mad6913
Jun 05, 2020Aspirant
I bought new RAX200 router, would not connect to internet at all, factory resets, modem power cycles, etc
Found out through Netgear
Tech Support,
1. Factory default router
2. Power cycle Modem
3. Reboot Router
4.must login to router directly, with hardwire to port 2,
5.login Routerlogin.net
Run through initial set up, once logged into router.
6. Go to Ethernet
7. SCROLL DOWN TO BOTTOM
8. make sure it states "Use Computer Mac Address"
9. APPLY
10. internet issues should be resolved,
11. Go to Nighthawk APP
12. Complete set up of router on App.
Hope this helps..
Tech Support,
3. Reboot Router
6. Go to Ethernet
9. APPLY
Hope this helps..
